Failed to get a buffer pool.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to get a buffer pool. Socket ID = %p1% Application socket handle = %p2% Stub socket handle = %p3% Socket type = %p4% Socket family = %p5% Socket protocol = %p6% Local inet address = %p7% Local port = %p8% Remote inet address = %p9% Remote port = %p10%
Name | Type |
p1 | sInt |
p2 | uInt32 |
p3 | uInt32 |
p4 | xInt32 |
p5 | xInt32 |
p6 | xInt32 |
p7 | VarFmtByteArray |
p8 | uInt16 |
p9 | VarFmtByteArray |
p10 | uInt16 |
