A component using the fcntl() function failed while attempting to restore the socket option flags. Look up the errno definition for a more specific cause.
Restart the IO module by disabling followed by enabling the slot. Or Report the problem to your switch support contact.
Error
An attempt to restore the socket flags using fcntl() failed for file descriptor %sockfd% retuning errno %errnoStr% for slot %slotNo% and conduit Type %conduitType%.
| Name | Type |
| slotNo | uInt |
| conduitType | String |
| sockfd | sInt |
| errnoStr | String |
