A pseudo-wire received an event that is not valid. The requested event was rejected and the pseudo-wire did not take any action because of the event.
Since no action was taken, the affected pseudo-wire may still be functioning proplerly; however, if the the pseudo-wire is not functioning properly, disabling and enabling the L2VPN or CES container for the pseudo-wire may restore normal operation. To enable/disable an L2VPN, use the "enable/disable l2vpn" command. To enable/disable a CES, use the "enable/disable ces" command. If the problem continues, disabling and enabling MPLS will cause this internal table to be reset. To enable/disable MPLS, use the "enable/disable mpls" command.
Error
A FSM event (%event%) for the pseudo-wire with index %pwIndex% was invalid %action%
| Name | Type |
| pwIndex | uInt32 |
| event | uInt |
| action | Printf |
