cm.sys.ApplCfgObjUnsuprt
Description
Applications will fail to load configuration objects of unsupported features when a configuration file generated with a different EXOS version is used to configure the switch. This may occur during an EXOS upgrade or downgrade. Saving configuration in the current version of EXOS will create a new configuration file without the configuration objects related to unsupported features. Please be sure to have a backup of the old configuration file to be able to revert to the previous version of EXOS, when required.
Remedy
Saving configuration with the 'save configuration' command and rebooting with the new configuration file as the selected configuration file will no longer result in this event.
Severity
Warning
Message Text
The \"%appl%\" application \"%obj%\" configuration object is not supported.
Message Parameters
Name Type
appl String
obj String
