The DHCP address range configured for the mentioned VLAN does not match the configured subnet.
Make sure the the range configured is on the same network as the VLAN's primary IP address. You can do this with the configure VLAN dhcp-address-range command.
Error
Configured DHCP address range for VLAN %vlan% does not belong to it's subnet
| Name | Type |
| vlan | VLAN |
