HAL.Sys.TempCritical
Description
The Power Fan Controller located on the MSM has reported that the chassis temperature is reaching the limits of the operating range. If the temperature does not return to normal, the PFC could shut down the chassis.
Remedy
Replace the fans if they have failed or improve air circulation around the system.
Severity
Critical
Message Text
Chassis air intake temperature (50C) is out of operating range. System shutting down.
Applicable Platforms
