ExtLibA.SockLib.UseTLSFailNonTCPSock
Description
Attempted to use TLS on a socket which is not TCP or SCTP.
Remedy
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Severity
Error
Message Text
Attempted to use TLS on a socket which is not TCP or SCTP: Socket ID = %p1% Socket type = %p2% Socket family = %p3% Socket protocol = %p4% Application handle = %p5% Stub socket handle = %p6% Remote inet address = %p7% Remote port = %p8%
Message Parameters
Name Type
p1 sInt
p2 xInt32
p3 xInt32
p4 xInt32
p5 uInt32
p6 uInt32
p7 VarFmtByteArray
p8 uInt16
