NetDBMgr.AllocMemFail
Description
Memory for the displayed object could not be allocated which may be due to the system running low on memory. This will result in incorrect network database operations.
Remedy
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim memory. Once sufficient system memory is reclaimed, it is recommended that netDbMgr process be restarted for internal state to be fully rebuilt.
Severity
Error
Message Text
Memory allocation failed when trying to allocate a %obj% structure of size %size%.
Message Parameters
Name Type
obj String
size uInt32
