The Advanced Edge License includes all Edge License features and the features in the following table.
ExtremeXOS Advanced Edge License Features
| ExtremeXOS Software Feature | Supported Platforms |
| EAPS Advanced Edge—multiple physical rings, and "common links", also known as "shared port". | All platforms. |
| ERPS-more domains (allows 32 rings with matching ring ports) and multi-ring support | All platforms. |
| ESRP-Full | All platforms. |
| ESRP-Virtual MAC | All platforms. |
| OSPFv2-Edge (limited to max of 4 active interfaces) | All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches). |
| OSPFv3-Edge (limited to max of 4 active interfaces) | All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches). |
| PIM-SM-Edge (limited to max of 4 active interfaces) | All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches). |
| VRRP | All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches). |
| VXLAN | Summit X770, X670-G2, and ExtremeSwitching X870, X690. |
| OVSDB | Summit X770, X670-G2, and ExtremeSwitching X870, X690. |
| PSTag | Summit X460-G2, X670-G2, X770, and ExtremeSwitching X870, X690 series switches. |
