host-route
Use host routes when the switch resides in a network that uses routing protocols other than OSPF.
Syntax
Command Parameters
<A.B.C.D>
Specifies the IP address of the host router in a.b.c.d format.
metric <0-65535>
Configures the metric (cost) for the host route.
Default
None
Command Mode
OSPF Router Configuration
