install-cert-file
Specifices the certificate file path and file name for OVSDB.
Syntax
Command Parameters
WORD <1-128>
Specifies the path and file name of the OVSDB certificate.
Default
None
Command Mode
OVSDB Configuration
Usage Guidelines
This command does not apply to all hardware platforms. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
