show auto-sense qos
Displays the Auto-sense configuration related to overriding 802.1p bits.
Syntax
Default
None.
Command Mode
User EXEC
Command Output
The show auto-sense qos command displays the following information:
Output field
Description
802.1p OVERRIDE ENABLE
Displays if ports override incoming 802.1p bits on ports that operate in Auto-sense UNI or voice mode.
The following example displays the command output.
Switch:1>show auto-sense qos
                                 AUTO-SENSE GLOBAL Config
802.1p OVERRIDE
ENABLE
TRUE
 0 out of 0 Total Num of AUTO-SENSE entries displayed
