Displays information about the rendezvous points (RPs) for this PIM-SM domain.
show ip pim rp-hash
None
User EXEC
The show ip pim rp-hash command displays the following information:
Output field |
Description |
GRPADDRESS |
Shows the IP address of the multicast group. When combined with the group mask, it identifies the prefix that the local router uses to advertise itself as a C-RP router. |
GRPMASK |
Shows the address mask of the multicast group. When combined with the group address, it identifies the prefix that the local router uses to advertise itself as a C-RP router. |
ADDRESS |
Shows the IP address of the C-RP router. |
HOLDTIME |
Shows the time specified in a C-RP advertisement that the BSR uses to time out the RP. After the BSR receives an advertisement for the RP, it restarts the timer. If no advertisement arrives before the timer expires, the BSR removes that RP from the RP set. |
EXPTIME |
Shows the time that remains before this C-RP router times out. |
