ip dhcp-relay fwd-path {A.B.C.D} (for a
VLAN)
Create the forwarding path from the client to the server.
Syntax
default ip dhcp-relay
fwd-path {A.B.C.D}
ip dhcp-relay
fwd-path {A.B.C.D}
no ip dhcp-relay
fwd-path {A.B.C.D}
Command Parameters
- {A.B.C.D}
- Creates a forwarding path to
the Dynamic Host Configuration Protocol (DHCP) server with a mode and a
state. A.B.C.D is the IP address of the server. The default IP address of
the relay is the address of the interface.
![Tip](images/tip.png)
Tip
If the relay is a Virtual Router configured on this interface, you
must set the vrid.
Command Mode
VLAN Interface Configuration
