Displays the IS-IS Multi-area SPB IPv6 redistribution configuration for a specific Virtual Router Forwarding (VRF) instance.
show isis multi-area ipv6 redistribute vrf WORD<1-16>
The default is none.
User EXEC
This command does not apply to all hardware platforms. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
The show isis multi-area ipv6 redistribute vrf WORD<1-16> command displays the following information:
Parameter |
Description |
DIRECTION |
Indicates the direction of the redistribution policy. |
ENABLE |
Indicates if the redistribution policy is enabled on the switch. |
RPOLICY |
Indicates the route policy for IS-IS Multi-area SPB IPv6 redistribution for a specific VRF. |
Displaying the IS-IS Multi-area SPB IPv6 redistribution configuration for the VRF instance:
Switch:1>show isis multi-area ipv6 redistribute vrf VRF1
ISIS Multiarea Redistribute List for ipv6 unicast - VRF VRF1
DIRECTION ENABLE RPOLICY
remote-to-home TRUE Test
