ip ospf apply accept
Apply OSPF accept policy changes to allow the configuration changes in the policy to take effect in an OSPF Accept context (and to prevent the switch from attempting to apply the changes one by one after each configuration change).
Syntax
Command Parameters
[vrf WORD<1-16>]
Specifies the name of the VRF.
apply
Commits entered changes. Issue this command after modifying any policy configuration that affects an OSPF accept policy.
Default
The default is disabled.
Command Mode
User EXEC
