Create and configure a connectivity-association (CA).
Configure a CA name in multiples of 4 characters (4 bytes). If the total number of characters in a CA name is not a multiple of 4, it can create interoperability issues with EXOS or Switch Engine products.
macsec connectivity-association WORD<5-32> connectivity-association-key WORD<10-64> [key-parity {even | odd}]
no macsec connectivity-association WORD<5-32> connectivity-association-key WORD<10-32>
even — generates even-numbered keys
odd — generates odd-numbered keys
This parameter only applies to static MACsec configurations.
None
Global Configuration
This command does not apply to all hardware platforms. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
