untagged-traffic (for a port)
Associate (VID, portList) end points to the Switched UNI (S-UNI) service instance identifiers (I-SID).
Syntax
Command Parameters
bpdu enable
Enables BPDU forwarding.
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
Default
None
Command Mode
ELAN I-SID Configuration
