Configures the Virtual Router Redundancy Protocol (VRRP) priority for the elected Distributed Virtual Routing (DvR) VLAN. Switches advertise their priority to use in the primary router election process.
default dvr controller vrrp-on-dvr-isids priority
dvr controller vrrp-on-dvr-isids priority <1-254>
The default value is 100.
Global Configuration
This command only applies to DvR Controllers. For information on DvR Controller support, see Fabric Engine and VOSS Feature Matrix.
