Display Link Layer Discovery Protocol (LLDP) transmission TLVs for transmission on a specific port.
show lldp tx-tlv port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
a single slot and port (slot/port)
a range of slots and ports (slot/port-slot/port)
a series of slots and ports (slot/port,slot/port,slot/port)
all ports on the same slot (slot/all)
all ports on the switch (all)
None
Privileged EXEC
The show lldp tx-tlv port command displays the following information:
Output field |
Description |
Port |
Specifies the port number. |
PortDesc |
Specifies the port description transmission TLV. |
SysName |
Specifies the system capabilities transmission TLV. |
SysDesc |
Specifies the system description transmission TLV. |
SysCap |
Specifies the system name transmission TLV. |
Switch:1>show lldp tx-tlv port 1/2 ======================================================= LLDP port tlvs ======================================================= ------------------------------------------------------- Port PortDesc SysName SysDesc SysCap LocalMgmtAddr ------------------------------------------------------- 1/2 enabled enabled enabled enabled enabled
