Configures LLDP on a port or ports.
lldp port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} cdp
lldp port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} status <txAndrx>
Identifies the slot and port in one of the following formats:
a single slot and port (slot/port)
a range of slots and ports (slot/port-slot/port)
a series of slots and ports (slot/port,slot/port,slot/port)
all ports on the same slot (slot/all)
all ports on the switch (all)
Specifies LLDP frames to transmit and receive on the selected port(s).
The default is enabled.
The default is none.
GigabitEthernet Interface Configuration
