duplex (for the management port)
Configure the duplex mode for the Ethernet management port.
Syntax
Command Parameters
<half|full>
Specifies half- or full-duplex mode. 1 and 10 Gb/s ports must use full-duplex mode.
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
Default
The default is half-duplex mode.
Command Mode
mgmtEthernet Interface Configuration
Usage Guidelines
This command is not supported on 5320 Series.
