Display individual Virtual Link Aggregation Control Protocol (VLACP) statistics for specific ports to manage network performance.
show interfaces gigabitEthernet statistics vlacp [history] [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Identifies the slot and port in one of the following formats:
a single slot and port (slot/port)
a range of slots and ports (slot/port-slot/port)
a series of slots and ports (slot/port,slot/port,slot/port)
all ports on the same slot (slot/all)
all ports on the switch (all)
None
Privileged EXEC
The show interfaces gigabitethernet statistics vlacp command displays the following information:
Output field |
Description |
PORT NUM |
Shows the slot and port number. |
TX VLACPDU |
Shows the number of VLACPDUs transmitted on the port. |
RX VLACPDU |
Shows the number of valid VLACPDUs received on the port. |
SEQNUM MISMATCH |
Shows the number of mismatched VLACPDUs in terms of received sequence numbers on the port. |
