virtual-service WORD<1-128> install
Installs the virtual service package.
Syntax
Command Parameters
package WORD<1-512>
Specifies the package to be installed.
WORD<1-128>
Specifies the virtual service name.
Default
None
Command Mode
Privileged EXEC
Usage Guidelines
This command does not apply to all hardware platforms. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
This command also works in Global Configuration mode but does not display if you use the question mark (?) help in that mode to view the list of available commands.
