Use this task to view Management Instance statistics.
show mgmt statistics [clip | oob | vlan]
show mgmt ip icmp-statistics
OR
show mgmt ipv6 icmp-statistics
show mgmt ip ip-statistics
OR
show mgmt ipv6 ip-statistics
show mgmt ip tcp-connections
OR
show mgmt ipv6 tcp-connections
show mgmt ip tcp-statistics
OR
show mgmt ipv6 tcp-statistics
show mgmt ip udp-endpoints
OR
show mgmt ipv6 udp-endpoints
show mgmt ip udp-statistics
OR
show mgmt ipv6 udp-statistics
enable
clear mgmt statistics
Switch:1>show mgmt statistics ============================================================================== Mgmt Interface Stats Information ============================================================================== INST DESCR RX-PKTS RX-ERROR RX-DROP TX-PKTS TX-ERROR TX-DROP ------------------------------------------------------------------------------ 1 Mgmt-oob1 111667 0 0 21412 0 0 3 Mgmt-clip 0 0 0 0 0 0 4 Mgmt-vlan 28 0 0 7 0 0 5 Mgmt-sdwan 43337 0 0 99 0 0 4 out of 4 Total Num of mgmt interfaces displayed ------------------------------------------------------------------------------
Switch:1>show mgmt ip icmp-statistics ================================================================================ Mgmt ICMP Statistics Information ================================================================================ InMsgs : 44 InErrors : 0 InCsumErrors : 0 InDestUnreachs : 44 InTimeExcds : 0 InParmProbs : 0 InSrcQuenchs : 0 InRedirects : 0 InEchos : 0 InEchoReps : 0 InTimestamps : 0 InTimestampReps : 0 InAddrMask : 0 InAddrMaskReps : 0 OutMsgs : 53 OutErrors : 0
Switch:1>show mgmt ipv6 icmp-statistics ================================================================================ Mgmt ICMPv6 Statistics Information ================================================================================ InMsgs : 58 InErrors : 0 InCsumErrors : 0 InDestUnreachs : 0 InTimeExcds : 0 InParmProbs : 0 InPktTooBigs : 0 InRedirects : 0 InEchos : 0 InEchoReps : 0 InGroupMembQueries : 0 InGroupMembReductions : 0 InRouterSolicits : 0 InRouterAdvertisements : 55 InNeighborSolicits : 0 InNeighborAdvertisements : 3 InMLDv2Reports : 0 InType134 : 55 InType136 : 3 OutMsgs : 69 OutErrors : 0 OutDestUnreachs : 0 OutTimeExcds : 0 OutParmProbs : 0 OutPktTooBigs : 0 OutRedirects : 0 OutEchos : 0 OutEchoReps : 0 OutGroupMembQueries : 0 OutGroupMembResponses : 0 OutGroupMembReductions : 0 OutRouterSolicits : 0 OutRouterAdvertisements : 0 OutNeighborSolicits : 13 OutNeighborAdvertisements : 0 OutMLDv2Reports : 56 OutType133 : 56 OutType135 : 13 OutType143 : 0 --------------------------------------------------------------------------------
Switch:1>show mgmt ip ip-statistics ================================================================================ Mgmt IP Statistics Information ================================================================================ InReceives : 1231729 InHdrErrors : 0 InAddrErrors : 489 InUnknownProtos : 0 InDiscards : 0 InDelivers : 1221886 OutRequests : 1212585 OutDiscards : 20 OutNoRoutes : 0 ForwDatagrams : 0 ReasmTimeout : 0 ReasmReqds : 0 ReasmOKs : 0 ReasmFails : 0 FragOKs : 0 FragFails : 0 FragCreates : 0 --------------------------------------------------------------------------------
Switch:1>show mgmt ipv6 ip-statistics ================================================================================ Mgmt IPv6 Statistics Information ================================================================================ InReceives : 226 InHdrErrors : 0 InAddrErrors : 0 InUnknownProtos : 0 InDiscards : 0 InDelivers : 62 InTooBigErrors : 0 InNoRoutes : 0 InTruncatedPkts : 0 InMcastPkts : 224 InOctets : 20556 InMcastOctets : 20416 InBcastOctets : 0 InNoECTPkts : 226 InECT1Pkts : 0 InECT0Pkts : 0 InCEPkts : 0 OutRequests : 71 OutDiscards : 0 OutNoRoutes : 0 OutForwDatagrams : 0 OutMcastPkts : 69 OutOctets : 5412 OutMcastOctets : 5272 OutBcastOctets : 0 ReasmTimeout : 0 ReasmReqds : 0 ReasmOKs : 0 ReasmFails : 0 FragOKs : 0 FragFails : 0 FragCreates : 0 --------------------------------------------------------------------------------
Switch:1>show mgmt ip tcp-connections =================================================================================== Mgmt IP TCP connections =================================================================================== STATE RECV-Q SEND-Q Local Address:Port Peer Address:Port ----------------------------------------------------------------------------------- LISTEN 0 5 0.0.0.0:ftp 0.0.0.0:* LISTEN 0 5 0.0.0.0:telnet 0.0.0.0:* LISTEN 0 40 0.0.0.0:https 0.0.0.0:* LISTEN 0 1 0.0.0.0:login 0.0.0.0:* ESTAB 0 0 192.0.2.10:https 198.51.100.1:50694 ESTAB 0 3 192.0.2.10:telnet 198.51.100.1:58862 ESTAB 0 0 192.0.2.10:https 198.51.100.1:59774 ------------------------------------------------------------------------------------
Switch:1>show mgmt ipv6 tcp-connections ================================================================================= Mgmt IPv6 TCP connections ================================================================================= STATE RECV-Q SEND-Q Local Address:Port Peer Address:Port --------------------------------------------------------------------------------- LISTEN 0 5 *:ftp *:* LISTEN 0 5 *:telnet *:* LISTEN 0 40 *:https *:* LISTEN 0 1 *:login *:* ---------------------------------------------------------------------------------
Switch:1>show mgmt ip tcp-statistics ================================================================================ Mgmt Combined IPv4/v6 TCP Statistics Information ================================================================================ TcpActiveOpens : 9571 TcpPassiveOpens : 9658 TcpAttemptFails : 17 TcpEstabResets : 86 TcpInSegs : 1207867 TcpOutSegs : 1199088 TcpRetransSegs : 42 TcpInErrs : 0 TcpOutRsts : 89 TcpInCsumErrors : 0 --------------------------------------------------------------------------------
Switch:1>show mgmt ipv6 tcp-statistics ================================================================================ Mgmt Combined IPv4/v6 TCP Statistics Information ================================================================================ TcpActiveOpens : 9626 TcpPassiveOpens : 9713 TcpAttemptFails : 17 TcpEstabResets : 86 TcpInSegs : 1212159 TcpOutSegs : 1203293 TcpRetransSegs : 42 TcpInErrs : 0 TcpOutRsts : 89 --------------------------------------------------------------------------------
Switch:1>show mgmt ip udp-endpoints ======================================================================================== Mgmt IP UDP endpoints ======================================================================================== STATE RECV-Q SEND-Q Local Address:Port Peer Address:Port ---------------------------------------------------------------------------------------- UNCONN 0 0 0.0.0.0:bootpc 0.0.0.0:* UNCONN 0 0 0.0.0.0:tftp 0.0.0.0:* UNCONN 0 0 192.0.2.10:ntp 0.0.0.0:* UNCONN 0 0 0.0.0.0:ntp 0.0.0.0:* UNCONN 0 0 0.0.0.0:snmp 0.0.0.0:* ---------------------------------------------------------------------------------------
Switch:1>show mgmt ipv6 udp-endpoints ========================================================================================================= Mgmt IPv6 UDP endpoints ========================================================================================================= STATE RECV-Q SEND-Q Local Address:Port Peer Address:Port --------------------------------------------------------------------------------------------------------- UNCONN 0 0 [0:0:0:0:0:0:0:1]:domain *:* UNCONN 0 0 *:tftp *:* UNCONN 0 0 [fe80:0:0:0:f66e:95ff:fe9f:81]:ntp *:* UNCONN 0 0 [fe80:0:0:0:f66e:95ff:fe9f:a5]:ntp *:* UNCONN 0 0 [fe80:0:0:0:a8bb:ccff:fedd:ee01]:ntp *:* UNCONN 0 0 [fe80:0:0:0:fce7:79ff:fe04:999c]:ntp *:* UNCONN 0 0 [fe80:0:0:0:609a:4aff:fe4e:cf04]:ntp *:* UNCONN 0 0 [fe80:0:0:0:c482:2aff:fe75:2e66]:ntp *:* UNCONN 0 0 [fe80:0:0:0:c80a:73ff:fe00:364e]:ntp *:* UNCONN 0 0 [fe80:0:0:0:80cc:e9ff:fec7:b9e2]:ntp *:* UNCONN 0 0 [fe80:0:0:0:64da:41ff:fec5:489e]:ntp *:* UNCONN 0 0 [fe80:0:0:0:f8d7:d6ff:feda:62bc]:ntp *:* UNCONN 0 0 [fe80:0:0:0:f66e:95ff:fe9f:0]:ntp *:* UNCONN 0 0 [0:0:0:0:0:0:0:1]:ntp *:* UNCONN 0 0 *:ntp *:* UNCONN 0 0 *:snmp *:* --------------------------------------------------------------------------------------------------------
Switch:1>show mgmt ip udp-statistics ================================================================================ Mgmt UDP Statistics Information ================================================================================ UdpInDatagrams : 63622 UdpNoPorts : 44 UdpInErrors : 0 UdpOutDatagrams : 63666 UdpIgnoredMulti : 0 UdpRcvbufErrors : 0 UdpSndbufErrors : 0 UdpInCsumErrors : 0 --------------------------------------------------------------------------------
Switch:1>show mgmt ipv6 udp-statistics ================================================================================ Mgmt UDP6 Statistics Information ================================================================================ Udp6InDatagrams : 0 Udp6NoPorts : 0 Udp6InErrors : 0 Udp6OutDatagrams : 0 Udp6IgnoredMulti : 0 Udp6RcvbufErrors : 0 Udp6SndbufErrors : 0 Udp6InCsumErrors : 0 --------------------------------------------------------------------------------
