Configure the remote host address for log transfer. The system transfers the current log file to a remote host after the log file size reaches the maximum size.
  • The IP address you configure for the remote host must be reachable at the time of configuration.
    enable
    configure terminal
  2. Configure the remote host address for log transfer:
    logging transferFile {1-10} address {A.B.C.D} [filename—prefix WORD<0–200>]
Switch:1(config)# logging transferFile 1 address 192.0.2.10
The following table defines parameters for the logging transferFile command.
Variable
Value
1–10
Specifies the file ID to transfer.
address {A.B.C.D}
Specifies the IP address of the host to which to transfer the log file. The remote host must be reachable or the configuration fails.
filename-prefix WORD<0–200>
Specifies the name of the file on the remote host. If you do not configure a name, the current log file name is the default.
