Enable an Access Policy
Enable the access policy feature globally to control access across the switch.
You can create an access policy to control access to the switch. An access policy specifies the hosts or networks that can access the switch through access services; for example Telnet, SNMP, and Hypertext Transfer Protocol (HTTP).
  1. In the Device Physical View tab, select the Device.
  2. In the navigation pane, expand Configuration > Edit.
  3. Select Chassis.
  4. Select the System Flags tab.
  5. Select EnableAccessPolicy.
  6. Select Apply.
