You cannot enable Node Alias on SPBM NNI ports.If you disable Node Alias globally, port level functionality is also disabled.
The steps in this procedure assume Node Alias is disabled globally as well as on ports.
Perform the following procedure to configure Node Alias.
enable
configure terminal
nodealias max-clients <max-clients>
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Display basic information for Node Alias clients:
Switch:1>show nodealias
              Node Alias - General Info
    NodeAlias is globally enabled:                 TRUE
    Maximum Number of Clients:                     8192
    Port List NodeAlias Enabled:                   1/14,1/17,2/1
    Number of learned clients:                     5
    Number of active clients:                      5
    Number of protocol related entries:            6
