Configure PIM-SM to enable or disable PIM-SM globally on the switch and change default global parameters.
Before you can enable the PIM Infinite Threshold Policy feature, you must first disable the following:
  • PIM-SM
  • PIM-SSM
  • Simplified vIST
PIM-SM is the default mode so you do not need to configure the PIM mode.
    enable
    configure terminal
  2. Enable PIM-SM:
    ip pim enable
  3. Configure the time between bootstrap messages:
    ip pim bootstrap-period <5–32757>
  4. Configure the timeout to discard data:
    ip pim disc-data-timeout <5–65535>
  5. Enable the fast join prune interval:
    ip pim fast-joinprune
  6. Configure the forward cache timeout:
    ip pim fwd-cache-timeout <10–86400>
  7. Configure the interval for join and prune messages:
    ip pim join-prune-interval <1–18724>
  8. Specify how long to suppress register messages:
    ip pim register-suppression-timeout <6–65535>
  9. Specify how often the candidate-rendezvous point (C-RP) sends advertisements:
    ip pim rp-c-adv-timeout <5–26214>
  10. Configure PIM Infinite Threshold Policy:
    1. Disable PIM-SM.
      no pim enable
    2. Enable PIM Infinite Threshold Policy:
      ip pim spt-infinite-threshold
    3. Enable PIM-SM:
      ip pim enable
  11. Configure the polling interval for the routing table manager (RTM):
    ip pim unicast-route-change-timeout <2–65535>
  12. Verify the configuration changes:
    show ip pim
Switch:1(config)#show ip pim
Switch:1>show ip pim
                        Pim General Group - GlobalRouter
PimStat               : disabled
Mode                  : sparse
StaticRP              : disabled
FastJoinPrune         : disabled
SptInfiniteThreshold  : enabled
BootstrapPeriod       : 60
CRPAdvTimeout         : 60
DiscDataTimeout       : 60
FwdCacheTimeout       : 210
RegSupprTimeout       : 60
UniRouteChangeTimeout : 5
JoinPruneInt          : 60
