After you assign the IP address, you can configure ARP. By default, ARP Response is enabled and Proxy ARP is disabled.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  1. In the Device Physical View tab, select a port.
  2. In the navigation pane, expand: Configuration > Edit > Port.
  3. Select IP.
  4. Select the ARP tab.
  5. In DoProxy, select enable to enable the Proxy ARP function.
  6. In DoResp, select enable to configure the system to respond to an ARP. The default is enable.
  7. Select Apply.
    The ARP function is available only when the port or VLAN is routed; that is, it is assigned an IP address.
ARP Field Descriptions
Use the data in the following table to use the ARP tab.
Name
Description
DoProxy
Configures the system to respond to an ARP request from a locally attached host or end station for a remote destination. The default value is disable.
DoResp
Configures the system to send ARP responses for this IP interface address. The default value is enable.
