Determines for which applications TACACS+ collects accounting information. Use TACACS+ accounting to track the services that users access and the amount of network resources that users consume. If unassigned, TACACS+ does not perform the accounting function.
User log on and log off
Log off generated because of activity timeout
Unauthorized command
Telnet session closed (not logged off)
If unassigned, TACACS+ does not perform the accounting function. No default value exists.
enable
configure terminal
tacacs accounting enable cli
no tacacs accounting cli
tacacs accounting disable [cli]
Enable TACACS+ accounting:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#tacacs accounting enable cli
