Use the following procedure to clear Internet Protocol Security (IPSec) system statistics counters and view IPSec statistics on an interface. The device only clears system statistics counters on system reboot.
View IPSec statistics. Output is partial due to length.
Switch:1>show ipsec statistics system ================================================================================ IPSEC Global Statistics ================================================================================ InSuccesses = 0 InSPViolations = 0 InNotEnoughMemories = 0 InAHESPReplays = 0 InAHFailures = 0 InESPFailures = 0 OutSuccesses = 0 OutSPViolations = 0 OutNotEnoughMemories = 0 generalError = 0 InAHSuccesses = 0 InESPSuccesses = 0 OutAHSuccesses = 0 OutESPSuccesses = 0 OutKBytes = 0 OutBytes = 0 InKBytes = 0 InBytes = 0 --More-- (q = quit) Switch:1>show ipsec statistics gigabitethernet 1/13 ================================================================================ Ipsec Port Stats ================================================================================ Ifindex = 204 InSuccesses = 0 InSPViolations = 0 InNotEnoughMemories = 0 InAHESPReplays = 0 InAHFailures = 0 InESPFailures = 0 OutSuccesses = 0 OutSPViolations = 0 OutNotEnoughMemories = 0 generalError = 0 Switch:1>show ipsec statistics vlan 1 ================================================================================ Ipsec Vlan Stats ================================================================================ Ifindex = 2049 InSuccesses = 0 InSPViolations = 0 InNotEnoughMemories = 0 InAHESPReplays = 0 InAHFailures = 0 InESPFailures = 0 OutSuccesses = 0 OutSPViolations = 0 OutNotEnoughMemories = 0 generalError = 0
View IPSec statistics for a loopback interface:
Switch:1>show ipsec statistics loopback 1 ================================================================================ Ipsec LoopBack Stats ================================================================================ Ifindex = 1344 InSuccesses = 0 InSPViolations = 0 InNotEnoughMemories = 0 InAHESPReplays = 0 InESPReplays = 0 InAHFailures = 0 InESPFailures = 0 OutSuccesses = 0 OutSPViolations = 0 OutNotEnoughMemories = 0 generalError = 0
Use the data in the following table to use the show ipsec statistics command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
loopback <1–256> |
Identifies the loopback interface. |
system |
Shows statistics for the entire system. |
vlan <1-4059> |
Specifies the VLAN. |
