Configure SLPP Globally
Enable the Simple Loop Prevention Protocol (SLPP) to detect a loop and automatically stop it.
- Select SLPP.
- Select the Global tab.
- Select GlobalEnable.
- In TransmissionInterval, type a value for the time interval for loop detection.
- Select Apply.
Global Field Descriptions
Use the data in the following table to use the Global tab.
Name |
Description |
GlobalEnable |
Activates or disables SLPP globally. The default is disabled. |
TransmissionInterval |
Configures the interval for which loop detection occurs. The interval is expressed in milliseconds in a range from 500–5000. The default value is 500. |
Job aid
The following table provides the SLPP values.
Enable SLPP |
Setting |
Access SMLT |
Yes |
Core SMLT |
No |
Primary switch |
Packet Rx threshold |
5 |
Transmission interval |
500 milliseconds (ms) (default) |
Secondary switch |
50 |
500 ms (default) |
