Use this procedure to display information about the multicast groups traversing the snoop enabled router.
- Select IPv6 MLD.
- Select the Snoop Trace tab.
Snoop Trace Field Description
Use the data in the following table to use the Snoop Trace tab.
Field |
Description |
GrpAddr |
Specifies the IP multicast address of the group traversing the router. |
SrcAddr |
Specifies the IP source address of the multicast group address. |
OutVlan |
Specifies the egress VLAN ID for the multicast group. |
OutPort |
Specifies the egress port of the multicast group. |
InVlan |
Specfies the ingress VLAN ID for the multicast source. |
InPort |
Specifies the ingress port for the multicast group. |
Type |
Specifies the port type on which the snoop entry is learnt. |
