Use IP forwarding (routing) on a global level so that the device supports routing. You can use the IP address of an interface for IP-based network management.
You cannot configure this option on a DvR Leaf node.
Activate IP forwarding and view the forwarding configuration:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrf green Switch:1(router-vrf)#ip routing Switch:1(router-vrf)#show ip routing ================================================================================ IP - GlobalRouter ================================================================================ IP Forwarding is enabled IP ECMP feature is disabled Maximum ECMP paths number is 1 ECMP 1 pathlist : ECMP 2 pathlist : ECMP 3 pathlist : ECMP 4 pathlist : ECMP 5 pathlist : ECMP 6 pathlist : ECMP 7 pathlist : ECMP 8 pathlist : Gratuitous-Arp : enable IP Alternative Route feature is enabled IP More Specific Non Local Route feature is disabled IP ICMP Unreachable Message is disabled IP Supernetting is disabled IP Icmp-echo-broadcast-request is enabled IP Default TTL is 255 seconds IP ARP life time is 360 minutes IP Source Route Option is disabled
Use the data in the following table to use the show ip routing command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-512> |
Specifies a VRF instance by VRF number. |
