Switch:1>show ip vrrp address ==================================================================================================== VRRP Info - GlobalRouter ==================================================================================================== VRRP ID P/V IP MAC STATE CONTROL PRIO ADV VERSION ORIGIN ---------------------------------------------------------------------------------------------------- 10 2 203.0.113.2 00:00:5e:00:01:0a Init Disabled 255 1 2 config 1 222 11.1.1.1 00:00:5e:00:01:01 Init Disabled 255 1 2 config 1 223 15.1.1.1 00:00:5e:00:01:01 Init Disabled 255 1 3 config 3 out of 3 Total Num of VRRP Address Entries displayed. VRRP ID P/V MASTER UP TIME HLD DWN CRITICAL IP(ENABLED) VERSION HOSTNAME -------------------------------------------------------------------------------------------------------- 10 2 0.0.0.0 0 day(s), 00:00:00 0 0.0.0.0 (No) 2 1 222 0.0.0.0 0 day(s), 00:00:00 0 0.0.0.0 (No) 2 1 223 0.0.0.0 0 day(s), 00:00:00 0 0.0.0.0 (No) 3 3 out of 3 Total Num of VRRP Address Entries displayed. VRRP ID P/V BACKUP MASTER BACKUP MASTER STATE FAST ADV (ENABLED) VERSION -------------------------------------------------------------------------------------------------------- 10 2 disable down 200 (NO) 2 1 222 disable down 200 (NO) 2 1 223 disable down 200 (NO) 3 3 out of 3 Total Num of VRRP Address Entries displayed. VRRP ID P/V VIRTUAL ADDRESS -------------------------------------------------------------------------------------------------------- 1 222 11.1.2.1 1 223 15.1.2.1 2 out of 2 Total Num of VRRP Virtual Address Entries displayed.
Use the data in the following table to use the show ip vrrp address command.
Variable |
Value |
addr <A.B.C.D> |
Specifies the physical local address of the master VRRP. |
vrf WORD<1-16> |
Specifies the name of the VRF. |
vrid <1-255> |
Specifies a unique integer value that represents the virtual router ID. The virtual router acts as the default router for one or more assigned addresses. |
vrfids WORD<0-512> |
Specifies the ID of the VRF. |
version <2–3> |
Specifies the VRRP version to include in the command output. |
