Configure a port as trusted or untrusted to determine the Layer 2 QoS actions the switch performs. A trusted port (override disabled) honors incoming 802.1p bit markings. An untrusted port (override enabled) overrides 802.1p bit markings.
Enable DiffServ.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Configure the port as Layer 2 untrusted:
    qos 802.1p-override [enable]
  3. Configure the port as Layer 2 trusted:
    no qos 802.1p-override [enable]
Use the data in the following table to use the qos 802.1p-override command.
Variable
Value
enable
If you use this variable, the port overrides incoming 802.1p bits; if you do not use this variable, the port honors and services incoming 802.1p bits. The default is disable (Layer 2 trusted).
