View Current BSR Information
View the current BSR information to review the configuration.
  • You must disable static RP.
  1. In the navigation pane, expand Configuration > IP.
  2. Select PIM.
  3. Select Current BSR tab.
Current BSR Field Descriptions
Use the descriptions in the following table to use the Current BSR tab.
Name
Description
Address
Shows the IP address of the current BSR for the local PIM domain.
FragmentTag
Shows a randomly generated number that distinguishes fragments that belong to different bootstrap messages. Fragments that belong to the same bootstrap message carry the same fragment tag.
HashMask
Shows the mask used in the hash function to map a group to one of the C-RPs from the RP set. The hashmask allows a small number of consecutive groups to always hash to the same RP.
Priority
Shows the priority of the current BSR. The C-BSR with the highest BSR priority and address (referred to as the preferred BSR) is elected as the BSR for the domain.
BootStrapTimer
Shows the bootstrap timer. After the bootstrap timer expires, the BSR sends out bootstrap messages.
