Configure the port QoS level to assign a default QoS level for all traffic if the packet does not match an access control list (ACL) that re-marks the packet. If you configure port QoS levels, Layer 2 and Layer 3 traffic from the same port use the same QoS level. The default value is 1.
For VoIP traffic, as a best practice, use QoS level 6.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure the port QoS level:
    qos level [port {slot/port[sub-port]}] <0-6>
Variable definitions
Use the data in the following table to use the qos level command.
Variable
Value
<0-6>
Specifies the default QoS level for the port traffic. The system reserves QoS level 7 for network control traffic. The default is 1.
port {slot/port[/sub-port]}
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
