Configure a specific advertising Backbone Edge Bridge (BEB) with a specific I-SID to allow you to apply the IPv6 IS-IS accept policy to routes for a specific advertising BEB.
If the route policy changes, you must re-apply the IPv6 IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
You must configure a route-map.
Change the VRF instance as required to configure an IPv6 IS-IS accept policy for a particular advertising BED and I-SID on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
- Select IS-IS.
- Select the Accept Nick-Name Isid tab.
- Select Insert.
- In the AdvertisingRtr field, specify the SPBM nickname.
- In the Isid field, specify an I-SID number.
- Select Enable to apply the filter.
- Optional: In the PolicyName field, specify the route-map name.
- Select Insert.
Accept Nick-Name Isid Field Descriptions
Use the data in the following table to configure the Accept Nick-Name Isid tab.
Name |
Description |
AdvertisingRtr |
Specifies the SPBM nickname to apply the IS-IS accept policy to routes for a specific advertising BEB. |
Isid |
Specifies the I-SID value. The value 0 is used for the Global Router. |
Enable |
Enables or disables the I-SID entry. The default is disabled. |
PolicyName |
Specifies the route policy name. You must configure a policy earlier in a separate procedure. |
