View information about the temperature for each sensor on the device.
The system triggers an alarm when one of the zones exceeds the threshold temperature value.
- In the Device Physical View tab, select the chassis.
- Select Chassis.
- Select the System Temperature tab.
System Temperature Field Descriptions
Use the data in the following table to use the System Temperature tab.
Name |
Description |
SensorIndex |
Specifies the range of sensors on the device. |
SensorDescription |
Specifies the name of the sensor. |
Temperature (degrees celsius) |
Specifies the sensor temperature measured in Celsius degrees. |
WarningThreshold |
Specifies the temperature value of the warning threshold for the sensor. When the temperature crosses the warning threshold a warning message is generated. |
CriticalThreshold |
Species the temperature value of the critical threshold for the sensor. When the temperature crosses the critical threshold, a critical message is generated or the system shuts down, depending on hardware capability. |
Status |
Specifies the current temperature status based on the warning and critical thresholds. |
