View the VRF Configurations
Use the following command to view VRF configurations.
View the VRF configuration:
Switch:1#show ip ospf vrf virtualrandf1 ================================================================================ OSPF General - VRF virtualrandf1 ================================================================================ RouterId: 192.0.2.1 AdminStat: disabled VersionNumber: 2 AreaBdrRtrStatus: false ASBdrRtrStatus: false Bad-Lsa-Ignore: false ExternLsaCount: 0 ExternLsaCksumSum: 0(0x0) TOSSupport: 0 OriginateNewLsas: 0 RxNewLsas: 0 TrapEnable: false AutoVirtLinkEnable: false SpfHoldDownTime: 10 Rfc1583Compatibility: disable default-metric : ethernet - 100 --More-- (q = quit)
Variable definitions
The following table defines parameters for the show ip ospf vrf command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
