Use this procedure to view the secure channel (SC) outbound statistics using EDM.
  1. In the Device Physical View tab, select one or more ports for which you need to view the SC outbound statistics.
    For information about which ports support MACsec, see the hardware documentation.
  2. In the navigation pane, expand Configuration > Edit > Port folders.
  3. Select General.
  4. Select the SC Outbound Stats tab.
    Use the Clear Stats button to the clear single-port secure channel outbound statistics. The Clear Stats button is not available to clear multiple-port secure channel outbound statistics.
SC Outbound Stats Field Descriptions
The following table describes the fields in the SC Outbound Stats tab.
Field
Description
ProtectedPkts
Specifies the number of integrity protected but not encrypted packets for this transmitting SC.
EncryptedPkts
Specifies the number of integrity protected and encrypted packets for this transmitting SC.
OctetsProtected
Specifies the number of plain text octets that are integrity protected but not encrypted on the transmitting SC.
OctetsEncrypted
Specifies the number of plain text octets that are integrity protected and encrypted on the transmitting SC.
