Use this procedure to view FA interface configuration.
The following example displays sample outputs for the show fa interface command.
Switch:1>show fa interface
Fabric Attach Interfaces
INTERFACE SERVER MGMT MGMT MSG AUTH MSG AUTH TCN ORIGIN
STATUS ISID CVID STATUS KEY
Port 1/1 enabled 0 0 enabled ****
Port1/10 enabled 0 0 enabled ****
Port1/6 enabled 0 0 enabled ****
Port1/11 enabled 0 0 enabled ****
Mlt2 enabled 0 0 enabled ****
5 out of 5 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the port 1/6.
Switch:1>show fa interface port 1/6
1 out of 4 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the MLT 2.
Switch:1>show fa interface mlt 2
Variable definitions
The following table defines parameters for the show fa interface port command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
The following table defines parameters for the show fa interface mlt command.
Variable |
Value |
<1–512> |
The valid range for MLT ID. |
