Use the following procedure to display the configured IKE policies.
Switch:1#show ike policy
                                   IKE Policy
Policy                Addr                                                       Profile
 Name                 Type Local Address              Remote Address             Name
iketest3              IPv4 192.168.152.104            192.168.149.207            test
v1pol                 IPv4 192.168.152.104            192.168.152.152            ikepro
                                   IKE Policy
Policy                Profile                                   Revocation-Check     peer-identity
 Name                 Version     Auth-Method    Pre-Shared Key       Method               name
iketest3              2           digital-cert                        ocsp
v1pol                 1           digital-cert                        ocsp
                                   IKE Policy
Policy                DPD        Admin   Oper          Use IKE
 Name                 Timeout     State  State P2 PFS  DH Grp  DH Group IntfId
iketest3              300        enable  up    disable enable  modp1024 3047
v1pol                 300        enable  up    disable enable  modp1024 3047
Variable Definition
The following table defines parameters for the show ike policy command.
| Variable | Value |
| policy WORD<1–32> | Specifies the name of the policy to be displayed. |
| laddr WORD<1–256> | Specifies the local IPv4 or IPv6 address. |
| raddr WORD<1–256> | Specifies the remote IPv4 or IPv6 address. |
