Use this procedure to generate a certificate signing request (CSR) and store it into a file. This CSR is required to obtain the offline subject certificate.
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Generate the CSR:
    certificate generate csr <subject-label>
  3. Configure where to send the CSR for signing:
    certificate send-csr-to <A.B.C.D> <user> <remote-path> <subject-label>
The following table defines parameters for the certificate generate csr command.
Variable
Value
<subject-label>
Specifies the subject identity.
The following table defines parameters for the certificate send-csr-to command.
Variable
Value
<A.B.C.D>
Specifies the IP address for the certificate authority.
<remote-path>
Specifies the file path on the certificate authority.
<subject-label>
<user>
Specifies the user name for the certificate authority.
