Disable ECMP before you configure route preferences.
Important
Changing route preferences can affect system performance and network accessibility while you perform the procedure. You must therefore change a prefix list or a routing protocol before you activate the protocols.
Configure IP route preferences to give preference to routes learned for a specific protocol. You must disable ECMP before you configure route preferences.
To configure route preferences for a VRF, access VRF Router Configuration mode, rather than Global Configuration mode.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#show ip route preference
IP Route Preference - GlobalRouter
PROTOCOL DEFAULT CONFIG
LOCAL 0 0
STATIC 5 5
ISIS-INTERNAL 7 140
OSPF_INTRA 20 20
OSPF_INTER 25 25
EBGP 45 45
RIP 100 100
OSPF_E1 120 120
OSPF_E2 125 125
ISIS-EXTERNAL 130 9
IBGP 175 175
View the route preference configuration for a specific VRF, for example 444.
Switch:1>enable
Switch:1(config)#router vrf test
Switch:1(router-vrf)#show ip route preference vrf 444
IP Route Preference - VRF 444
LOCAL 0 0
STATIC 5 5
ISIS-INTERNAL 7 135
OSPF_INTRA 20 20
OSPF_INTER 25 25
EBGP 45 45
RIP 100 100
OSPF_E1 120 120
OSPF_E2 125 125
ISIS-EXTERNAL 130 11
IBGP 175 175
Variable definitions
Use the data in the following table to use the ip route preference protocol command.
Variable |
Value |
ebgp |
Protocol type for ebgp. |
ibgp |
Protocol type for ibgp. |
isis-external |
Protocol type for IS-IS external routes. |
isis-internal |
Protocol type for IS-IS internal routes. |
ospf-extern1 |
Protocol type for ospf-extern1 routes. |
ospf-extern2 |
Protocol type for ospf-extern2 routes. |
ospf-intra |
Protocol type for ospf-intra routes. |
ospf-inter |
Protocol type for ospf-inter routes. |
rip |
Protocol type for rip routes. |
static |
Protocol type for static IP routes. |
<0-255> |
Specifies the preference value for the specified protocol. |
