Create an IP VPN instance to advertise IP routes from one VRF to another across a Shortest Path Bridging MAC (SPBM) network.
You must configure the required SPBM IS-IS infrastructure.
The VRF must exist.
VPN Field Descriptions
Use the data in the following table to use the VPN tab.
Name |
Description |
VrfId |
Specifies the ID of the VRF to configure. |
Enable |
Enables or disables the IP VPN instance on the VRF. The default is disabled. |
Isid Number |
Specifies the I-SID to associate with the VPN. By default, no I-SID is assigned. |
Isid Name |
Specifies the name of the I-SID associated with the VPN. |
