View and manage general IPv6 information.
Switch:1(config)#show ipv6 interface vlan
Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT MCAST IPSEC RPC RPCMODE
INDX ADDRESS STATE STATE LMT TIME TIME STATUS
2070 22 e4:5d:52:3c:65:02 disable down ETHER 1500 64 30000 1000 disable disable disable existonly
Vlan Ipv6 Address
IPV6 ADDRESS VLAN-ID TYPE ORIGIN STATUS
fe80:0:0:0:e65d:52ff:fe3c:6502 V-22 UNICAST LINKLAYER INACCESSIBLE
1 out of 2 Total Num of Interface Entries displayed.
1 out of 2 Total Num of Address Entries displayed.
Switch:1#show ipv6 interface tunnel
Tunnel Ipv6 Interface - GlobalRouter
IF Descr VLAN PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT MCAST
6656 T-1 0 n/a enable down P2P 1280 64 30000 1000 disable
Tunnel Ipv6 Address
IPV6 ADDRESS TUNNEL-ID TYPE ORIGIN STATUS
11:0:0:0:0:0:11:11/32 T-1 UNICAST MANUAL INACCESSIBLE INF INF
fe80:0:0:0:0:0:b0b:b0b/64 T-1 UNICAST LINKLAYER INACCESSIBLE INF INF
1 out of 5 Total Num of Interface Entries displayed.
2 out of 9 Total Num of Address Entries displayed.
Switch:1#show ipv6 address interface tunnel 2
Address Information
IPV6 ADDRESS/PREFIX LENGTH VID/BID/TID TYPE ORIGIN STATUS
44:211:0:0:0:0:0:2/64 T-2 UNICAST MANUAL PREFERRED
fe80:0:0:0:0:0:d301:3702/64 T-2 UNICAST LINKLAYER PREFERRED
2 out of 407 Total Num of Address Entries displayed.
Switch:1#show ipv6 address interface vlan 100
Address Information
10:1:50:0:0:0:0:7/64 V-100 UNICAST MANUAL PREFERRED
fe80:0:0:0:b2ad:aaff:fe46:f19a/64 V-100 UNICAST LINKLAYER PREFERRED
Switch:1#show ipv6 forwarding
Ipv6 forwarding - GlobalRouter : enable
ecmp : disable
ecmp-max-path : 1
Switch:1#show ipv6 global
IPv6 Global Information - GlobalRouter
forwarding : disable
default-hop-cnt : 64
number-of-interfaces : 1
icmp-error-interval : 1000
icmp-error-quota : 50
icmp-unreach-msg : disable
icmp-addr-unreach-msg : enable
icmp-port-unreach-msg : enable
icmp-echo-multicast-request : enable
static-route-admin-status : enable
alternative-route : enable
ecmp : disable
ecmp-max-path : 1
source-route : disable
host-autoconfig : disable
Switch:1#show ipv6 nd interface vlan
Vlan Ipv6 Nd - GlobalRouter
IFID VLAN RTR-ADV MAX-INT MIN-INT LIFETIME MANAG OTHER DAD-NS MTU HOP
FLAG CONF LIMIT
TIME TIME
2092 V-44 True 600 200 1800 False False 1 0(d) 64(d) 30000(i) 1000(i)
2081 V-33 True 600 200 1800 False False 1 0(d) 64(d) 30000(i) 1000(i)
Note: (s) = Set, (d) = Default, (i) = inherit.
2 out of 2 Total Num of Ipv6 ND Entries displayed.
Switch:1#show ipv6 nd-prefix interface gigabitethernet
Port Ipv6 Nd Prefix
INTF IPV6 BTR VALID PREF EUI
INDEX ADDRESS/PREFIX LIFE LIFE
344 2011:beef:4004:0:0:0:0:0/64 5/25 2592000 604800 1
1 out of 9 Total Num of Ipv6 ND prefix Entries displayed.
Switch:1#show ipv6 nd-prefix interface vlan
Vlan Ipv6 Nd Prefix
INTF IPV6 VLAN VALID PREF EUI
INDEX ADDRESS/PREFIX ID LIFE LIFE
2148 2011:beef:100:0:0:0:0:0/64 100 2592000 604800 1
2158 2011:beef:110:0:0:0:0:0/64 110 2592000 604800 1
2248 2011:beef:200:0:0:0:0:0/64 200 2592000 604800 1
2258 2011:beef:210:0:0:0:0:0/48 210 2592000 604800 1
2548 2011:beef:500:0:0:0:0:0/64 500 2592000 604800 1
2648 2011:beef:600:0:0:0:0:0/64 600 2592000 604800 1
2948 2011:beef:900:0:0:0:0:0/64 900 2592000 604800 1
7 out of 9 Total Num of Ipv6 ND prefix Entries displayed.
Switch:1#show ipv6 nd-prefix vlan 100
Nd-Prefix Address Information
Legend: EUI: eui-not-used(1), eui-used-with-ul-complement(2)eui-used-without-ul-complement(3)
Switch:1#show ipv6 neighbor type 4
Neighbor Information - GlobalRouter
NET ADDRESS/ IPV6 PHYS TYPE STATE LAST TUNNEL
PHYSICAL ADDRESS INTF INTF UPD
123:0:0:0:0:0:0:123/ C-1 cpp LOCAL REACHABLE 0 days 00h:00m:01s
00:00:00:00:00:01
1 out of 1 Total Num of Neighbor Entries displayed.
Switch:1(config)#show ipv6 neighbor
22:0:0:0:0:0:0:22/ V-22 1/2 DYNAMIC REACHABLE 0 days 00h:00m:01s
84:83:71:49:38:82
22:0:0:0:0:0:0:44/ V-22 cpp LOCAL REACHABLE 0 days 00h:00m:00s
d4:ea:0e:c8:8c:81
fe80:0:0:0:8683:71ff:fe49:3882/ V-22 1/2 DYNAMIC DELAY 0 days 00h:00m:00s
84:83:71:49:38:82
fe80:0:0:0:d6ea:eff:fec8:8c81/ V-22 cpp LOCAL REACHABLE 0 days 00h:00m:00s
d4:ea:0e:c8:8c:81
Use the data in the following table to use the show ipv6 commands.
Variable |
Value |
address interface ip WORD<0-46> |
Specifies the IPv6 address. |
neighbor [WORD<0-46>] |
Specifies the IPv6 address of the neighbor. |
loopback <1-256> |
Specifies the loopback interface ID value. If you do not specify a value, the output includes all IPv6 loopback interfaces. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
type <1–4> |
Specifies the neighbor type as one of the following:
tunnel <1–2000> |
Specifies the tunnel ID. |
vlan <1-4059> |
vrfWORD<1–16> |
Specifies the VRF name. |
vrfidsWORD<1–256> |
Specifies the VRF ID. |
