  1. Enter IS-IS Router Configuration mode:
    enable
    configure terminal
    router isis
  2. Enable the Controller globally:
    spbm <1-100> multicast spb-pim-gw controller enable
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#spbm 1 multicast spb-pim-gw controller enable
Variable definitions
The following table defines parameters for the spb command.
Variable
Value
<1-100>
Specifies the isis spbm instance-id to create the spbm instance.
controller enable
Enables the SPB-PIM Gateway Controller.
